Hey all my name is Scott and I'm new here to the site. I'm having a problem with my 88 full size jimmy and I'm stumped. My truck will start up and run great then suddly will die but both injectors on the throttlebody will keep spraying fuel like the throttle is opened all the way. This issue just pops up randomly and happened a couple months ago I ended up replacing the ICM but problem still was there then i replaced the coolant temp sensor and cleaning the grounds and problem went away. How having problem again. I replaced the CTS again to see if that was the problem but it continues to die with injectors dumping fuel in to the throttle Body. Any help would be greatly appreciated.
