Midwestern4x4Parts
88 Chevy K5 350 TBI 350 Trans 203 T case. Ran great until fuel tank took a crap. Comes with new pump , and has a new sending unit with about 5 gallons through it. Has Dana 44 Front axle with 4.10 gears , and an open diff. Flat Top Knuckles , and External Drive Flanges. Rear axle is a Corp 14 Bolt with 4.10's and a welded carrier. Has a TPI Fuel pump so if you ever mod the motor the pump puts out enough pressure for almost whatever you need. Has clear Title , and Custom Bumpers. Also has 2 New Gas tank straps , and the trans has 10 miles on it. Rebuilt with mild Shift kit. Has 6" Lift with all spring no blocks. Springs , are Superlift , and all new. Tires are 44" , and have dry rot. They are at least %75+ Tread though , and they all hold air, and haven't leaked. Have alot Into it , and just need to get rid of it. Any Questions get ahold of me. (815) 791 5435 $1150 FIRM.
