pure country
Registered Member
I have an 88 K5, and recently I put a brand new 350 5.7 motor in it which I purchased from Jaspers motors. I also installed an edlebrock manifold, J.B.A. headers(smog legal), and a flex fan. We also put MSD coil,distributor,wires, and spark box. It has been 12 weeks, and we still can't figure out why the service engine soon light keeps coming on. The code that is regitered, is #43(timing,spark, and knock sensor). It only happens once in awhile. I can go all day with nothing, then there it is. We have changed the knock sensor,map sensor, the spark sensor, and the computer 5 times. We have also put the oringinal oem distributor back in, and disconnected the MSD box.
CAN SOMEONE OUT THERE PLEASE HELP ME AND 4 DIFFERENT MECHANICS FIGURE THIS OUT. We have ran all the electrical test, and all the wires are good. We have checked all of the grounds and they are good. We even did the code 43 diagnostic test, and it checks out, OK.
Someone must of had this problem before me, I can,t be the first one. I have been told that the edlebrock manifold is the problem. I would think that the guys at edlebrock would know if there product would work or not. If I am wrong, please tell me. I am so frustrated. We also up graded the exhaust pipes to 2 1/2 inch, not sure if this matters or not.
PLEASE HELP THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Also one really weird thing that happens: when the light comes on, I can put the truck into neutral(while I am still rolling down the freeway), and step on the gas pedal really hard, twice, and then put it back into drive, and the light will go off.
