ericcarney
I have an '88 K5 with an 8" lift and 39.5" TSL's. It rides good and turns without rubbing until i go up a driveway or over a curb or down in a rut. I can't put a body lift on it because I have to park it under my carport and I already had to trim an inch off the entrance so it would fit. I have my crossover stuff coming in sometime next week and I want to be able to get articulate after I put it on without rubbing. So I have a body work guy that is going to trim some off of the fenders, but I wanted to get an idea of how much to trim off. And how important is the fender well? Can I take it out? It only rubs on the corners so should I flare it at the ends? Will trimming the fender be enough? I read something about beating back the firewall, will i need to do that too? Should I trim the rear fenders too so it matches? What should I use to cover the rough edge of the cut? Or should I sand it? Any help would be appreciated.
