88 SUBURBAN Ventura, CA $ 8500
WYLDERK5
Registered Member
WYOMING
1988 GMC SUBURBAN 2500 SIERRA CLASSIC
PW/PL Front and Rear AC, TW Fuel Injected
ENG/TRAN
New ProCharger Supercharger- installed 6/15/09
Custom Intercooler, Dual Batteries
New Turbo 400 Transmission- installed 7/1/08
Gear Vendors Transmission Splitter
350 Crate Motor, Coated Headers, Stainless Steel Exhaust
Oversized Radiator, MSD Ignition, MSD Coil, Boost Gauge, Fuel Pressure Gauge, Tach
40 Gal Fuel Tank
Front and Rear Hitch
4" Lift Kit
Custom Skid Plate and Drive Shaft Saver
33 X 12.5 16 Pro Comp Extreme A/T Tires
Plus Everything Seen in Pictures-FULL VEHICLE HISTORY AVAILABLE
Drop me a pm if interested $8500
Man i saw the price and was like "what a dumb dumb", Then i saw the truck and read the desription, then i was like "Worth it!" Looks awesome!
How do you like the gear vendors? I have been considering one for a long while. Do you like it?
Works good well worth the investment. Drop's the RPM's Signifcant
I am enthralled with this truck because it seems to be built for a similar purpose as mine. It says this truck is in Ventura. Any issues with Smog in CA and the charger? Is it 50 state? Also, did the GV need a separate crossmember, or does the transfer case support it with no issues? How long have you been running the GV?
Sorry for all the questions. I really like how you have outfitted this truck. The ladder is tasteful, and the truck looks ready for battle.
-Dan
No issues on smog its legal and will pass.I'll have to look at the GV to see i don't remember drop it off at GV and picked it up when it was done. Never wheeled the Burb.Drove it back and forth to Wyoming was my hunting rig. Bought a cummins to replace Burb.
