88' TBI fuel gauge problem
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
Can anyone tell me why a fuel gauge will read correctly one minute, then peg out the next? It works first thing in the am and then several miles down and BAM! straight to the 3 o'clock position. Sometimes it will come back but not always. The frame is powder coated but ground clean at the fuel pump ground point on the frame. Grounds are good and clean still. Fuel pump is working fine and no leaks . PLEASE help!
Not sure what the answer is but I have a similar problem, my fuel gauge in the 89 doesn't work at all, it stays pegged at 3 o'clock all the time, although I don't think the frame ground is the cause of this because mine was clean as well.
The fuel gauge in my pickup pegs at 3 o'clock too--I checked all the wires,grounds,etc,but it turns out the sending unit rehostat must be junk..
I had swapped another tank into my truck and I failed to test the original sending unit (Truck had dual tanks and the drivers side leaked,so I just plumbed up the passenger side and ran it off that one,till I came across a good used drivers side tank)..I swapped the original sending unit to the "new" tank,and was bummed out to find after I had it all bolted in,the gauge would just peg out..
My truck is a diesel so the sending unit is a bit different than a gas truck,having the "water in fuel" sensor in the sending unit,plus another hose nipple for the factory water drain siphon hose feature..
I happened to have several gas sending units hanging around from other tanks I knew were good,plus one brand new one ,and I was able to get the plug and wires off the tank's sending unit and plug in one of the known good ones ,and grounded it--when I moved the float up and down with the key on,the gauge responded normally..
So it figures I'll have to drop the tank again someday..it weeps at the seam a bit anyways,so it will need replacing sooner or later..
There is a "right and left" sending unit for dual tanks,though I dont see why one just couldn't be spun 180 degrees and used on either side..I was told I can swap just the rheostat from one of the gas sending units onto the diesel one ,so I can retain the water in fuel sensor and siphon hose feature,though I doubt I'd miss either one of those things..
I found this troubleshooting guide for GM gauges online,its confusing,but might help diagnose the issues with them..Functional Tests of Factory GM Electric Gauges
