ThanksPurple is used in the neutral safety switch circuit, iirc.
Excellent info I will make sure neutral safety and reverse lamps are working tomorrow.Brake lamp switch wiring will be hot all the time. That might be related to 700r4 torque converter lockup. Which you don't have.
Neutral safety switch will be 2 12ga purple wires in a flat 2 wire plug, that plugs into switch at base of steering column, in cab.
This switch will have second set of terminals for the reverse lamps
The brake switch has two feeds one is plugged in from below an orange and WHITE edit wire. Then there is the one with pink blue and purple that looks like it could plug in also. It I didn’t want to fry any wiresThe empty spot your finger is pointing to is for the 700r4 vacuum switch, this switch was used to signal the unlock for the torque converter. You no longer need, with the B&M kit.
I am curious how the brake on signal works with current set up. Also make sure it still works after you finish your wiring. Never know if the installer tapped in somewhere and your new loom will eliminate that tap.
Interesting my 89 had cruise control and overdrive I guess that’s why there are to spots for switches. The cruise control is gone. I’m curious what would the switch do for OD if the B&M is installed should I complete the circuit or leave it disabledInteresting, downshift control relay hmm.
The pink with black is default 12v power circuit for computer sensors and actuators. No surprise there.
Iwhat year is that manual.
Down shift control relay, is new one me, and is probably part of the vacuum and wot switch system the pre tbi, and ccc, needed to function.
