89 5.7 tbi sputters and pops at idle
HookMeUp
Registered Member
Minnesota
89 5.7 tbi
Starts and runs fine when cold. Once the motor is up to temp it's another story. The motor starts hard and has a rough idle( I have to mash the pedal to the floor to keep it going sputters and pops). If I slightly tap the gas pedal either under load or in neutral. It seems to flood itself out. Any ideas?
thanks
I agree, check timing. Also, make sure timing advance wire is disconnected when tming, and reconnected when you are finished.
Single brown wire on drivers side firewall, engine side, with a weather pack connector.
I had this issue also twice.... Once when the Fuel Pump went out and once when the Pick Up Coil went out. But the timing is a good place to start, less labor and No $$$ involved.
If it runs fine when cold and crap when hot, I'd look into the coolant temp sensor. It might be giving the ECM a wrong temp reading and it doesn't know what to do.
