89-91 GUYS
blazen91
Hesperia, Ca 92345
When you flip on your brights, do all four head lights come on or just the center two? On low beams, my outer two are on and on high beam only the inner two are on. Are all four supose to be on, on high beam? TIA
<A target="_blank" HREF=http://www.blazen91.coloradok5.com>http://www.blazen91.coloradok5.com</A>
Protect the land FOR the people
Not FROM the people
That is the way it is supposed to do. Mine does the same thing. There is a wiring kit you can buy that lets all 4 lights stay when the high beams are on. Here are two that i found in the Summit catalog. Hope this helps.
Summit makes one part # SUM-G6219 $14.99
Painless Performance part # PRF-30802 $20.95
<A target="_blank" HREF=http://k5junkie.coloradok5.com/>http://k5junkie.coloradok5.com/</A>
The outer bulbs have three terminals. Why couldn't you just jump a wire over from the high side of the outer bulb to the inner bulb? Would it be too much for the exsiting system to run all four lights?
Not FROM the people
is there a kit like that for late model chevys?
