mudboggink5
I have an 89 blazer k5 that i purchased a couple of months ago. I noticed when i turned the heat or ac on, It would not work on the low setting or the middle setting, but when i put on high it blows out as it should. i drove it to work the other day and i had the heat on low and noticed it worked, so than i tryed the other settings and it worked also, so i figured it was fine. i left work and tryed it again, and the same thing, it would only blow out high. I'm thinking its a bad switch or the blower motor, did anyone else experiance this problem.
