89 blazer parts and more
k5texan
Flint, TX
white 89 blazer rolling. body is good except no doors, rear fenders are cut underneath moulding, and floor is cracked under the front seats. interior is grey no carpet dash is cracked rear is sprayed with line x. tailgate works fine along with ac and heater. make offer.
sits on a duelly dana 60 front with 410s 35 spline outers and warn lockout hubs and rear is factory 10 bolt. needs spring perches but have ubolts. 4 15x10 chrome mods 8 lug. $1200
no motor or tranny. i have the TBI system that worked great$300. also have a TPI complete manifold up with distributor alternator computer and wiring $300.
Also have a set of 2.5 ton rockwells that i went through and repacked all the bearings and cut off all the drum brakes(was going to run pinion brakes) with tires and wheels and driveshafts $1200.(sold)
also a gauge cluster and standard steering column from the 89 1 ton.
also big block radiator off 89 1ton-$65.00
make any reasonable offer.
i live in Tyler, TX i could meet with in an hour or so. thanks, Jared
do you have the sender assembly from the gas tank? I need the plug that attaches from the assembly to the pump itself. It actually is submerged in fuel when the tank is full.
does the guage cluster have a tach and how are the rear springs. PM me a price with shipping to 84118
Thanks
Would you sell just the 15x10 8 lug wheels? If so, price including shipping to 98665. Thanks!
Is the "hydralic sm 465 and np205 with crossmember" still available? I am interested if it is.
the gauge cluster does not have a tach
the springs are still attached to the truck and would like to sell with the whole truck
i need the wheels to roll the blazer around on till i sell the it or the axles.
the sm465/np205 does have the crossmember
jared
Any chance you have a hydro clutch pedal assembly? If so, I'm interested.
how much for the gage cluster
i have a 79 with a hydrolic sm 465 /forums/images/graemlins/deal.gif
