Rally Smith
Registered Member
My Dad has a 89 Blazer 5.7 auto that has been getting worse and worse. For some time now, while driving it hesitates for a split second and repeats every 10 seconds or so. It has gotten to the point that he's not confident that it will actually keep running if he goes into town.
He has replaced all vacuum lines, sprayed around manifold and TBI will no leaks detected. We found the distributor rotor moved side to side so it was replaced. Plugs were pulled and they looked great but replaced anyway.
Found a plug boot arcing to heat shield. Temporarily repaired to see if that was the cause. Not the cause. I checked for codes and there are none.
TBI is spraying nicely so that can't be it. So at this point the only thing that I can think that may be the problem is it needs new plug wires OR the knock sensor is retarding the timing because of an exhaust leak at the manifolds.
Anybody have more things to check?
Thanks,
Rick
Thanks,
Rick
