You can read about it in my build thread. I'll run it all down
I have kind of come to a cross roads in my dealings in 4x4 stuff.
Maybe thinking about selling the Crew cab.
How much interest????
89 V 3500 Crew cab frame shortened 42 inches, front 8 feet of frame has been boxed. DIY4X A-bomb front frame winch carrier/frame support, Rear portion of frame heavily gusseted. 144 inch wheelbase, 2 inch receiver welded into rear frame. ORD custom GM engine crossmember with DIY4X motor mounts.
Front springs = 1/2 ton blazer rear springs, 52 inch with 6 inch extended shackles
Rear springs = 3/4 ton Chevrolet truck 63 inch with DIY4X shackle flip and cross tied shackles.
Warn M12000 winch recently rebuilt
Dana 60F,4.56 spooled, C&M fabrication, brass Ampco kingpin bushing kit, Ballistic fab, Cross over steering arm, hydro-assist ram, 1.5 inch diameter solid cold rolled center link, GM 1 ton TRE's, 1410 yoke, 1.5 inch, 35 spline 4340 steel outer stubs, stock inners. RPM drive flanges, new wheel bearings w/races and seals, New 1480 front axle ujoints
GM corporate 14 bolt, 4.56 spooled, new R&P, seals, bearings. custom dual caliper(GM) disk brake brackets w/ rotors and calipers new brake pads all the way around. 1410 yoke, Fully plumbed axle, custom anti wrap bar, guardsman yoke protector fromDIY4X
14 inch travel procomp ES3000 shocks, custom mounted fronts, rears still need mounting,
2 wheel drive GM steering gearbox, DIY4X ported front cap and custom drilled and tapped top cover fro hydro-assist,
Freshly Rebuilt (has not been started)GM 350 new rings, bearings, pistons, seals, everything. Hottest cam available from summit racing for the TBI motor. will still provide plenty of vacuum. Motor is complete ready to start.
1999 ford Windstar elelctric fans, NEW big GM diesel radiator,
new heater core,
Chev truck gauge cluster w/ odometer set to 000000 with Tachometer
Jeep Cherokee steering shaft
Clean dash pad, no tears.
Chev Blazer 31 gallon fuel tank mounted custom behind cab above frame.
T400 custom rebuilt, new clutches, steels, gaskets, custom shift kit, fully manual, designed to shift very hard! New, still in the box B&M Z gate shifter
Custom NP241/NP205 doubler, with custom triple stick shifters, 205 rotated up for flat belly, 241 rotated up to keep belly flat also. 1410 yokes both front and rear outputs.
Rear Military truck lights ready to install.
H1 military tires 2nd gen.90% tread H1 rims with PVC inserts, rock rings and inner bead stiffners all welded and ready to roll, been holding air since 2010
Good glass and body panels relatively straight.
seats not installed, 2 - 1997 GM truck bucket seats. needs seat belts,
needs driveshafts built, Ebrake finished, exhaust finished, floor finished rear exterior lighting installed. needs battery and cables installed also. needs rear shock mounts installed, New GM truck SBC TBI exhaust Y pipe, universal cat and glass pack muffler.
I have numerous spare parts for the GM trucks all of it goes.
Whole lotta truck! $5000.00
I have 10 sticks of 1.75D .120 wall DOM and 2 pieces of .250 wall 2x3 rectangle tube for the future rocksliders. this is available to go with the truck for an additional $800.00
$5800.00 gets it all out of my garage into yours.
new heater core,
