ccarley
Don't forget to check the coil, and the pickup coil in the distributor! Ignition problems will drive you crazy, I know they drove me crazy.
My problem may have been the pickup coil; cheap part, and actually pretty easy to replace. I did the ignition module at the same time, just to be sure. My truck would fire up fine cold, run for 10 minutes, and then sputter and die. Turned out it would just stop sparking; we checked with a timing light; it would flash like it should, but on sputtering it was no longer flashing.
I also had a ground problem. The PO didn't do a good job on the chassis ground; wrapped the wires together and taped them. Worked OK for a while, but got corroded and was loosing connection. Sure the engine was grounded... so that was an interesting find. A lot of problems went away upon fixing the ground to the frame!
Good luck.
Good luck.
