89 K5 Blazer Measurement
Randybt
Registered Member
Waterloo, IL
Hi Everyone, My son and I are rebuilding a 1989 K5 Blazer. It had/has severe rush. The rear tail pan is trash as well as the front one for lack of a better name. The crossmember that both body mounts connect to is broke on both ends. I know how to repair but what I am questioning is the width between them and the actual length of the front tail pan. I believe the front one is right around 72 inches but want to confirm if someone can help. My interior has been removed so the 72 inch is in front of rear wheel well from side to side.
Thank you for the help!
If you can take a picture of where you want measurements, I’ll measure mine this week.
Everything but what you need...
Hi Big Ray, Wow, that is golden! I wish so badly I could find a dimension chart. I cant read it so small wont let me copy or print. Could you possibly email to me?
[email protected]. Thank you for everything!
Sorry picture so big. if you could measure just in front of fender well that covers rear tires side to side that is the measurement Im searching for.
Thank you so much! Randy
Sent a pic and a pdf...
All part of the service!
I couldn't get the other side of the tape, but I held it square and level across. I also got measurement of behind the wheel well. Virtually the same...
Sorry for this taking all week.
Jimmy85, This is PERFECT! Thank you so much. Definitely worth waiting for.... Let me know if I can help with anything, from what I see of yours its solid, congrats! My best! Randy
