My K5 was owned by an amateur radio enthusiast at some point. As in put-up-the-antenna-and-call-Sweden amateur radio. Wires running all over the place that I'm slowly removing.
Anyways, while working on my heater core today (or attempting to work on it
) I discovered this blue wire under the carpet on the passenger side floor board. Comes down the side of the body under the dash, is taped to the floor with that adhesive foam tape stuff, and then heads back along the edge of the floor next to the door.
Just wondering if I should put this one on my list or if it's factory. Rear speaker wire?
) I discovered this blue wire under the carpet on the passenger side floor board. Comes down the side of the body under the dash, is taped to the floor with that adhesive foam tape stuff, and then heads back along the edge of the floor next to the door.Just wondering if I should put this one on my list or if it's factory. Rear speaker wire?
