Sold 89 K5 Everything Works
ActionJosh7
Registered Member
Lake Stevens Washington
K5 Blazer I have daily driven the last 3 years. Fuel Injection 350, 700R4, 4x4, rear axle is 9 inch Currie, front axle is fully built 10 bolt both have chromoly axles. Original interior is well taken care of. Absolutely no rust other than a one inch single rub spot on passenger side seen in picture, rebuilt TBI, MSD ignition, new steering box, ORD braces, new distributor, front quad shocks, 35 inch tires (BFG ATs) with 70% tread, Yakima Bars. No leaks and spent first 25 years of life in Orange County CA, as a result it is rust free. 6 inch lift and truck has a little bump steer. EVERYTHING WORKS minus one temperamental door lock switch and one KC light periodically. Truck will need new seals soon. Garage kept. Located in Marysville Washington. $5500
Where is that rust spot? I didnt see it in any other picture. Roof?
The rust spot from the rub is two inches above the back of the passenger window channel. You can see it in the 3rd and 4th picture.
Looks like a nice truck it’s just on the wrong side of the country. Good luck with the sale.
