chevyfreak68
Newbie
I have a 89 k5 blazer I did a 5.3/4l60e swap in and I went and found a 98 with a np241 with a vss sensor I pulled the base that holes the vss and the 40 tooth reluctor ring everything is installed but when I try to put the base on it won't line up with the tabs on the plate that bolts to pump. If I grabbed the pump and that plate off the 98 and installed it on mine would it let everything line up?
