Hey yall,
I've been searching for help on this issue but I can find anything either problems like I'm having. Truck cranks and idles fine rev up is ok a few misses nothing major but as soon as I put it in drive and the rpm goes up to about 1200 it starts missing and sputtering and loses all power. Doesn't shut off but a strong wind will slow the truck down . It seems like it takes a min to change from first to second gear too . if I try to stomp it to passing gear it just bogs and doesn't go anywhere. You would think it goes from a 350 tho to a Briggs and Stratton . The only way I can get up to say 35mph is to feather the gas from wide open to foot off and it'll creep up but that's it.
Now I've replaced the egr about 2 yrs ago along with the throttle position sensor. I believe I've changed the map sensor too. Just replace the ignition control module again today . Noticed the cap and rotor needs to be replaced too but just don't want to throw money at it hoping it'll fix. I don't hear or notice and sparking from the wires. Replaced the fuel pump when I changed the egr. Also rebuilt the tbi back then too along with the computer. The only thing I can think of is the fuel pump relay , fuel pump pick up hose , filter, clogged cats which are about a yr old too. O2 sensor which is about 2yrs old. Anything past that I'm stumped. Thing idles like it should no lopes or anything. Acts like it's running lean. No gas smell at all. I pulled vacuum off the egr and sensor didn't change. Maybe someone else has dealt with this? I thought maybe the magnetic pick up on the dist. But wouldn't that be constant and not just under load. Any insight would be greatly appreciated!
