New to the forum, so if I'm doing something wrong just let me know. lol I bought an 89 4x4 k5 Blazer last summer and I'm trying to determine how much lift it has on it. The PO had it for 15 years and he said he installed a 3" block in the rear due to the saggy butt syndrome. As far as the lift goes, that's all I know. The center of hub to wheel well lip measurement is 24.5" on the front and 23.25" in the rear. I currently run tires that are a little over 33" tall uninstalled and 12.5" wide on 20x9 wheels. When the wheel is fully locked/turned to one side I have about 1" of clearance between the front corner of the fender and the tire. My goal is to have it sit a couple inches higher than it is now and run 35's. So I'm trying to determine how much higher a new 4" lift kit will put me. If it's not much then I may just add some zero rates, replace the old rancho shocks, and try to squeeze those 35's in once these wear out. I've seen some people measure their "stock" blazers and get 22.5" in the front and 21.5" in the rear which would lead me to believe I just have an inch or 2 above stock height. So if I could get ANY input on this matter based off yall's experience and maybe some of yall's measurements I'd greatly appreciate it! Also, what's the best way to upload pictures?? Can't seem to figure it out.
