omgwtf2
Registered Member
Hello to all,
I recently did a swap for a 96 350 Vortec with GM TBI to Vortec intake.
Here's my setup:
Re-used all my original sensors, Headers, ECM, TB and Distributor.
Put new A/C Plat Plugs & Wire. Base timing 0 Gap 35
Started up Idled smooth gave it some gas back-fired from both ends.
raised the fuel pressure from 12 to 16 and the back-fire stoped.
Took it for a ride and it pulled strong ater about a hour I had it parked and idling the engine stumbled then 10-15 seconds later it shut off. It started right up idled fine. Took it for a ride again got up to 30 mph and she started surging and like a small rumbling back-fire from the exhaust floored it and only got worse eased off the pedal and she limped back.
Replaced the Dist Module and spark plugs changed to startard risis. gap was 35.
Tried it again but got more driving time out of it before it started the same problem.
Codes 32 EGR 44 Lean o2 the EGR is not piped yet.
The TB has the AFPR, Pod spacer and Bore ridges removed / polished.
Any Ideas?
Here's my setup:
Any Ideas?
