8lug swap completed
If it was me, i would have pulled the whole axle off the donor axle.
I would have but everything was torn apart and everything knuckles out was gone except the hubs. The hubs were layin on the ground and stripped of their internals so I was all :woot:and :saweet: and what not cuz I got lucky and didnt have to do anything
So not to thread hijack, but I have seached the forum on this and looked at the tech article on the swap. So to do this on my 91' I would need the following:
spindles
hubs (rotors?)
caliper bracket
Is there more that I would need, will the calipers I have work?
Someone from PA go get some fresh eyes on this thing please.
Pat: PM is coming your way.
if some people would finish filling out there profile info then someone could help him out.
pa is a big state. as is others. :whistle:
Try the bearings and races from the 6 lug rotors in the 8 lug rotors.Sounds like the inner diameter of the bearings may be different. Just a thought...never mind talking to a "real" parts guy they interchange. Sounds like the problem is with the caliper mounting brackets. Did you by chance keep the bracket mounting bolts from the original 8 lug bracket? Could they be Thin head bolts? Just a thought
Finally got the salt out of my wounds
Well everybody im sorry to have left the thread dead but finally i can update you all. Hopefully with a few productive posts I can redeem myself:doah::doah:
I will give you guys a quick update followed by pictures.
First, I finally got the 14bolt in. Super simple swap and added the Ruff Stuff disc brake swap with ORD brake lines while I was at it.
Second, I never figured out the grinding on the front hubs so I found a complete axle in the junk yard for a song and transferred all of the new races and stuff onto it. Swapped that in a few hours. Got lucky with matching gear ratios (3.73). Got new calipers, discs, and brake lines.
Third, Shortly after I ended up moving back to Colorado:woot:where the Jimmy is waiting for me to install the DIY4x shackle flip kit, mini spool for the 14ff, and I just ordered the 37" hummer tires.
On to the pics
6 lugs
Sold the tires and rims
Goodbye 6lug 10bolt
just after the swap
And as she is back in Colorado
and if you happen to have a golf cart with a top or have a neighbor with one.... easy top removal:waytogo:
nice, whatever it takes to get it done and make sense, do it. I'm glad it didn't rust away while you're scratchin your head.
Ahhh it started to rust in PA:doah:
But I finally got some tires and rims off of craigslist, 37" hummer take offs.
Heres some poser pics. Time to get the sawzall out:waytogo:
