WY 9.5" 14 bolt spider gears
blazinzuk
Buzzbox voodoo
Rexburg Idaho
Any one got any.
My lock right is not working right and I need to get my jimmy going.
Even a gov lock and I'll send you my open carrier
what's up with the lock right?
At this point I'm not sure. It acts like there is too much space in between the side gear and the driver. Even though it's in spec. Just for kicks I replaced the side gear bushings, and the cross pin. No broken teeth or worn teeth. But under torque it slips badly.
Its done it since I first installed it. On road just fine but under throttle it skips.
I have a gov loc with 4.10 gears on it
I just need the carrier. I have 4.56 gears.
How much?
I have a gov-loc that I pulled the gears off of already. How does $20 plus the ride sound?
How much?
I guess you got it covered.
I Think I better keep it for someone that could use it all.
