Mudstud
Posting for a friend.
1990 Standard cab 454 TBI Auto Tranny 2wd with about 300,000 miles.
Problem- starts fine but stalls if foot isn't on the gas. Give it gas and runs normal. Just won't stay running unless you give it gas.
Says he's made sure fuel is getting to engine. Obviously cuz it will run.
Any thoughts on what to check next?
Thanks.
- He has put in a new distributer, points/condenser, button and cap.
- Has replaced both the electronic deals on the passenger side of the throttle body.
- Has replaced vacuum lines and hoses and has tightened down the TB.
Thanks.
