90 burb starting problems
efilnikufecin
flint,mi
i just got a 90burb i'm going to build a truggy out of it.it started and ran fine until i started pulling stuff off of it.i've pulled most of the body off(front clip,doors,only thing left is the floor boards and fire wall)i tried not to unhook anything i should not have but i guess i did.here what its doing.it turns over fine(acts like its not getting fuel).if i spray starting fluid in the throttle body it fires right up.the fuel pump is not working.so a ran a temp power line from the battery,now i can hear the pump spool up but it still won't start.any idea what i might have unhooked that will keep it from running?thanks
