90 IFS 4x4 STOCK suburban...width of front end? HELP!!
uglychevyZZ4
3/4 ton status
Black Diamond, Wa
I need the width from outer sidewall to outer sidewall on a 90 IFS 4x4 Burban.. i am supposed ot drive 150 miles tomorrow to pick one up and am trying to figure out if a tow dolley is wide enough.. HELP!!
Just measured my '94 for ya. It's at 78 inches, sidewall-to-sidewall. Mine has aftermarket wheels that have an additional inch of offset on each side, so figure 76 inches with stock wheels and even a bit less with the stock size tires. (Mine has 285/75R16's that are a tad wider than stock. )
Tow dolly isn't gonna be wide enough, but it's not enough to worry about. Just tighten the straps tight as you can, and check them now and then.
