Minnesota
After firing up the search feature, still have quick question. '90 K5 with serp. belt.
There is a hex fitting on the pulley shaft. I couldn't come away knowing whether this is a bolt that needs to be removed prior to using the puller tool. Got the impression that it might be part of the shaft itself, and pulley is 100% press-on. Conversely, I can't see how the installer tool wouldn't need something to thread into so as to push the pulley back on...
Thanks much!
Thanks much!
