90 k5 surpintine pulley
Justin Fleming
Oxford MI
Can anyone confirm if the tensioner serpentine pulley is right hand thread or left hand thread. My pulley bearing is wore out and whining so I want to replace it. Apparently the bolt is frozen in, I just want to make sure I am going the correct direction before I break it.
thanks
The tensioner, I ended up pulling the threads out. Had to heat with torch....end of the day it was a left hand thread.....:doah:
Now I wonder if I can through bolt it with standard right hand thread bolt. In theory it should work as the inner race should bottom out and the outter should spin around it....
