wayne
3/4 ton status
I've been fighting with this for days now. I need some input. I already had a post up but figured I would do one that is updated. Here is what's up.
90 K5 TBI 350. I swapped a used crate engine in. It ran awsome in the Burb I pulled it from. When I dropped it in the K5 I deleted the heater, AC, and cruise control. I removed everything and left only the engine wires in. I put on a new cap, rotor, plugs, wires, headers and 2.5" duals with no cats. It also got a new gas tank, pump, and filter. It runs good except when you put it in gear it stalls. If you give it gas you can keep it running though. I have replaced or changed since this started the fuel pump, filter, IAC, Computer, checked the TPS, timing, cap, and rotor. I put 3 different TBI units on with the same results. No matter what I do or change it does the same thing, start it up and it will idle all day, put it in gear and it stalls. Is it possible that it is the MAP sensor, pick up coil, or egr causing this? Everybody I talk to is pretty much clueless. It is not storing any codes either. I want ot wheel this on Sat. so I have 1 day left to figure this out so any help is appreciated!!!
Thanks everybody for the help.
