90 k5 tuff county springs to a 84 k30
84CUCV
3/4 ton status
NJ for now
they are pretty much new. hes telling me they will not fit. i wanted to check before i lay out the 150.
will fit right?? thanks
For the front? I think they are the same length. Why's he saying they won't fit? What does he think is differnt?
he said they are a little shorter and they are not as wide. just want to be sure
I could see the width being differnt. Some lift springs are narower.
Isn't the spring perch width the same on all the Chevy 4x4 fronts?
Front axles are the same. D60's use a differn't spring plate from the D44/10B. The pass side has studs comming out the perch machined into the diff.
1 ton rears have a differnt perch width.
