malignd1
Registered Member
Alright, i've done some scouring trying to pinpoint my current problem with the 90'k5 but cannot seem to get a complete resolution. I finally got the exhaust done to get her in and to pass emissions. She did fantastic as her numbers were less than 1/2 the legal amount now; b4 exhaust and egr valve replacement numbers were more than doubled so i am now really excited about where she's goin. But that isn t the problem.
It seems at right about 36-37mph the in dash brake light comes on and stays on until the ignition is turned off. It has been this way since I purchased the vehicle 8/2010. However, i noticed that if i lift up on the brake pedal the light will turn off, only to turn back on almost instantly, but only when speed exceeds 35mph. I've read posts in the forums where people have had a similar issue but can't seem to find a resolution and the threads end before actually stating a fix for it. I can drive around all day and it will never turn on unless 35mph speed exceeded. This has been frustrating at the least but on top of that, the other day when I was leaving the smog testing center the dash light came on and was blinking 9 short flashes and 1 long flash, over and over and over again. Even after turning the ignition off then back on. I let the truck sit overnight and went out yesterday and the flashing was no longer happening. FLuid level good; brake feel good; brake function seeming good...no issues. Im not a mechanic but am mechanically inclined but have limited resources. I wanted the truck to have something I can work on and could fix myself. Not that that's all that important but just thought id throw that in there for good measure. Any thoughts can help.
