91 14sf to 85 14ff Ebrake
dhcomp
1 ton status
Truckee, CA
Ok, so i know this has been discussed 100 times, but i am having a hard time figuring it all out.
I have a 91 burb, 14sf rear. Swapping for an 80's 14FF rear, with CUT CABLES.
What parts/pieces do i need to order to replace the cables on the 14ff rear, and hook up to my 91 setup?
Hoping i can just order everything from Rockauto and have a smooth conversion. With a non-functioning ebrake, my truck is worthless to me, as i tow a lot.
Thanks guys!
No one? Should i just order new rear cables for an 85 ish, or will my cables work?
i dont know for sure. but i have done brakes on both those axles with the big brakes. they both pretty much the same. and since you have a newer 14ff with the clip in cables, i would bet the current ones will work.
older 14ff (70's) had bolt on cables at the backing plate.
