Brazer
Newbie
I recently (about a month ago) installed a 4" Pro Comp spring lift on my 91 K5. Other than the lift, the drive train is bone stock, consisting of a 350, the 700r4, stock transfer case, stock differentials, etc.
Since installing the lift, i have noticed what i would consider a VERY slight drive shaft vibration at certain speeds.
Today when i got home, i noticed that the transmission has started to slightly leak. Not much, just a few drops, but i obviously want to nip this in the bud before it becomes an issue.
Being the first lifted vehicle i have owned, i am trying to find the best starting point for diagnosing the issue, and want to first elminate the lift having caused the issue. I am starting here because the lift DID NOT consist of a transfer case lowering kit.
Ultimately, my questions are:
1. what EXACTLY does the transfer case lowering kit do?
2. is there a chance that this could have created the transmission leak?
