smier
Tried searching, but no luck so far. My brake light started flashing... 6 short flashes followed by one long flash. Can't find my book, but I'm assuming it's an abs code. Any help is appreciated!
-- has bypassed it by unplugging the module.
Keep this in mind if you decide to disable it. If you are subjected to emissions testing like we are here in California the vehicle would FAIL a test instantly if the SES or ABS light is either not functioning or is on.
Your state laws may vary but i would check into it BEFORE you go removing it or disabling it.
