blazer88
Registered Member
I just sold my 91 Blazer to my sister. It has the 350 5.7l, and the 4l60 transmission. It has a four inch procomp lift, blocks in the rear and springs in the front, not sure if it has the drop pitman arm, it has 33x12.5 BFG All Terrains. I did not do the lift, I bought it this way. It was done at a shop, and I asume they knew what they were doing. But I drove it for nearly seven months, and put around 7000 miles on it. Pulled a trailer with it and tested out the four wheel drive a bunch of times. But before I sold it to her I made sure that everything was in great shape and it all is. She is complaining steering issues, these are her words "the steering is very loose, she often over corrects in turns because os sloppy/slow to respond, and bumps in the road are a cause for concern because it tracks into them and is hard to correct without over correcting." This was me second blazer and I think that it is just fine, I say that you don't really drive a blazer, you merely guide it and let it drive itself. She has it checked out at our local 4 Wheel Parts store/shop here in Fresno,Ca. The guys at the shop had different opinions about the steering, some felt it was loose, others felt it was fine. All parts checked out 100%. Nothing needs to be replaced, but she is worried that it is not safe to go the snow, and regardless of my persistence, she will not take my word that it is okay. Sorry for the long post, I hope that we gave enough information of the symptoms. If you need more info I will check this often. Please if you have any ideas hit me up on the forum. Thank you.
