Right now my pump does not cycle with the key in the run position or when cranking.
I checked power to the pump, no power.
I checked power to the relay, there is only power to one wire and it's when the pump should normally cycle on.
Shouldn't there be a constant power to the relay?
If so where should I start looking to find the issue?
I've also checked the fuses and they're all good.
I'm using a harness from street and performance and a 1227727 ECM
