RED MONSTER 4X4
Hey gang,
took apart my dash to clean and fix a few things, I know i should have been more careful and taken note of the light positions, at any rate I had 2 Mystery wires with Bulbs attached. one which was just a bulb with the screw lock(to connect to the holes in the gauge) the other on the right was a bulb with some connectors(and the lock)....now, i don't remember taking these off when i got the gauge cluster out, just the rectangle. noting i did could make either of the bulbs light up. My assumption is that the bulb(left) is for the 4x4 light, but i engaged it and it did not light up. but the one on the right is still a mystery.....any help would be appreciated. also the bulbs themselves are a mix of gray and blue....i am assuming blue is illumination and gray is indicators correct?
Just as a refresher, i have a 91 suburban 4x4 v2500 z82
