My good friend has a 91 burb that has just had the TBI 5.7 engine gone through. It was running really rough because it needed new tune-up parts. I replaced the following parts;
1. Brand new ignition module
2. New plugs
3. New plug wires
4. New fuel filter
5. New Dist cap and rotor
6. Static timed the engine and then set the ignition timing to 0*
7. Plugged Cat removed and straight pipe installed
8. Compression checked at 145psi all 8 cylinders
9. Scan tool showed on code 42 in memory and the O2 sensor seemed to hover between 434mv-473mv in open loop. I never did see it go into closed loop mode either as the engine warmed up....
10. Cleaned the IAC solenoid
11. New main and rod bearings
12. New timing chain set
13. New oil pump
His burb has a slight miss at idle as I can feel it in the rig, and when you blip the throttle while it's in Park or Neutral, it will rev up normally. But if I have him power brake it or test drive it going up a hill, it will literally buck and hesitate until you let off of the gas pedal.
The fuel coming out of the injectors has a nice spray pattern to it. Between the 2 of us we don't have a fuel pressure gauge to see what the pump is running at, but he said he didn't have this problem until the motor was gone through and installed again into the burb.
I'm either leaning towards the fuel pump, the pick up coil in the distributor, or maybe a faulty O2 sensor.....? Anyone have any ideas for me to try next to resolve the issue?
Thanks for your help,
Doug
2. New plugs
3. New plug wires
4. New fuel filter
13. New oil pump
Doug
