A friend has a 91 V2500 with a 5.7L gasser and a 4L80E trans. It was running great until their daughter went into the ditch at 55mph. After recovering it from the ditch, they drove it home but it ran rough and was burning rich. Here is the list if parts the shop replace (but it still runs the same):
Fuel pump (fuel pressure is 20 but the mechanic says it should 9-13).
Plugs, cap, rotor, and wires
Ignition module
MAP sensor
EGR valve
ECM
Throttle body (not sure if the injectors are new)
The fuel lines have been blown out and inspected for kinks.
Help!!??
Ignition module
MAP sensor
EGR valve
ECM
Help!!??
