91 burban with a tbi 454 need to get it to run
84CUCV
3/4 ton status
NJ for now
was swapped in. no fuel system yet. how can i rig this up to test it?? i have no idea how
thanks
what do you want to test, you want to hear it run? is the ignition hooked up? If so, all you have to do to make it run is put some gas in a soda bottle with an 1/8" hole in the lid and bottle feed it while its running through the throttle body with the air cleaner off. If the ignition is not hooked up, let me know. atleast check compression and make sure all 8 cylinders are within about 10% of each other.
i was hoping there was a way. i could get it to run and drive it around a bit. anyway to do that?
