Ok, so a few weeks after my trans was rebuilt, my speedo started jumping around on the highway. Brake light also comes on, im guessing from ABS computer freaking out.
If its cold out, i can drive for an hour or so before speedo starts jumping. If its warm, i drive for 15 or 20 min and it starts jumping. Doesn't jump constantly, but will jump around 10 to 15mph every 10 or 15 seconds. Wierd.
Figure my VSS in the transfer case is bad. Pickup a used one, same EXACT symptoms, so that must be bad. What else could it be? Does the ring it read in teh xfer case ever break? Had a bad/hard shift right before it started freaking out the first time.
Any thing else to check? I'm thinking maybe there is a short somewhere......
Thanks guys!
Thanks guys!
. Figure it will be easier to see what i've already gone through, plus see where it gets excessively hot or rubs.
