blazen88
Registered Member
if you get the radiator core support, grill, all the lights off of a 91 suburban will it be a direct bolt in a blazer. can you use your same radiator and condensor . working on a 88 blazer
Don't do it!
The '91 front is the ugliest of all model years, and the '88 front the best looking!
Of course, this is merely my personal opinion, and to each his own.
Don't do it!
I guess if you could find a guy with a '91 K5 who shared my opinion and give your '88 front to him, nothing will be lost.![]()
yup, all you have to do is splice some wiring
2nd i did this swap and it was easy BUT
i now wish i did not the older light over light would provide much more light
yea i think ill take better lighting over looks
This is true. It's hit or miss whether stores will even carry the small low and/or high beam. Plus, there was never a combination high/low bulb so you can't double up your lighting that way. The relay mod is definately worthwhile because it will cost less than $10.Keep your older grill. Not as many lighting options with bulb selectiom. ie. no Silver Stars for the '91 front end.
