91 horn?
dhcomp
1 ton status
Truckee, CA
Which horn was standard on the 91?
The one on my 03 is a joke, and want to replace it with the one from the older trucks.
Unfortunately, there are 2 or 3 different sounds/tones, and I don't want to pull the grill off the 91 to check the model number.
Anyone know which one came standard on the 91 square bodies?
AC delco lists a high tone, high output low tone, A, and F. A or F looks like the the same one i have, but i don't know which tone is which.
Thanks!
Not sure about a '91,but all the Gm trucks I've owned had 2 horns factory,a high and a low tone...most of them either failed to honk, or sounded like a dying moose,after 10 years or so..
My '82 pickup now has a horn off a BMW a friend was junking ,just to pass inspection..its weeny "beep-beep" sounds more like a horn a tiny car should have,not a 3 ton ingot 4x4!..kind of embarrassing to honk at people now..but it's "legal"..:crazy:
Older square bodies had one horn on each side of the radiator support behind the grille...the same green wire powers both,so you should be able to follow the wire and find the other one..
My truck's grille cant be removed due to the plow frame setup,someone welded the upper truss bar supports to the frame and they stick up several inches,so I'm boned if I need to ever change the trans cooler hoses or take the dead horns out,probably isn't enough room to snake the grille out,after removing the plow's head gear..--I'd have to lift the nose up or bust some chunks out of the grille..:(
