hi, im new to the site. i have a 91 k5 that had a tbi small block, i swithed it to a 90 454 from a r2500 suburban. i added headers, open element air cleaner, and wired in a heated bousch o2 sensor. the issue is it starts up and runs good for about 30 seconds, then the idle drops down and it starts backfiring out the exhaust (both sides) and it acts like it has a bad accelerator pump when you rev it up, like a severe hesatation and then it takes off like a bat out of hell. i also got rid of the lines that bring coolant to the adapter plate. base ign timing is 8 degrees btdc. also tried a new tps which did not help. any input would be greatly appreciated. thank you.
