Kjunky5
.... All shift points are done with spacer plate/valve body.
Shift firmness sure but shift points are from a combination of T.V. and governor pressure.
He's my $0.02. Replace cable and T.V. plunger/sleeve in the valve body. More than likely that is what is sticking. Should be stamped "94" on the end. Avoid "93". Sonnax makes a "hi-performance" one for another option.
I realize with a replacement governor the shift points could be "off" slightly compared to the one that has been riding in the trans for a while, any kind of pre-installation adjustment aside from making sure the teeth are good and the springs/weighs look OK?
