84CUCV
3/4 ton status
just started driving it again. here is a pic for the heck of it. few things popped up. the wipers dont return sometime and delay does not work at all. hi and low work.
second thing. there seems to be some wondering in the steering. before i parked it. i took off the mud tires. that helped a bit. tightened the steering box twice. helped too. still a bit there.
so where should i start thanks
j/k.I would check the ball joints,tie rod ends,wheel bearings and look very careful at the frame where the steering box bolts to they tend to crack behind the box.
But i did it
