Ok Guys my K5 just made it here. The tail gate glass goes down just fine from the key and the dash switch. However it has no up function.
Working either switch I saw no dimming of the dome lamp so I suspect the circuit is open. Now this safty switch that's build into the latch, is it only for up, down or?? I'm thinking if it only controls up, it sounds like a likely suspect.
I raised my glass via a cordless drill and it ran right up.
Thanks!
Oh, can I just pull the latch and bypass the harness, or can you bypass the harness without having to pull the latch?
Thanks!
