91 K5 ROOF RUST REPAIR
oonighttrain
Registered Member
palmetto fl
Long story short, i have a 91 k5 blazer that is pretty solid except for the rear corners of the metal roof which i found huge rust holes after removing the rear top.. so, i found what appeared to be a rust free metal roof from a guy.. i had it media blasted and found out it had quite a bit of pin holes.. any suggestions on how to reasonably repair the pin holes?
9
9
With that many holes your best option and best repair is to chop out that section and weld in new metal - just a series of spot weld about an inch apart to control the heat and warpage. Then go back to the first spot weld and repeat the process until you form a continuous weld. Grind smooth and paint.
Oh, and last two pics are just red X’s
