Leper
Was going to drive the Blazer around for old times sake and it would not start. Turns over fine, but no fuel from the injectors. When the key is cycled on you can hear a buzz from the fuel tank for a few seconds.With the line off at the fuel filter, and the key cycled on, fuel will run out of the line, but not under much pressure. With the lines off at the throttle body, nothing comes out. The truck will run with gas put down the throat of the throttle body. I put another five gallons in the tank just to make sure the pickup was under the fuel line. No change
The truck has sat on an incline for the better part of a year and I am thinking that the fuel pump has gone bad. I think the fuel should be shooting out of the line at the filter instead of just running out.
Is there anything else that would cause my problem? A ground I have overlooker? An ignition component that relates to the fuel pumps function?
Can you think of anything that would cause this?
TIA
Leper
TIA
Leper
