91 rear interior panel build
tj 413
Massachusetts
I thought about buying the rear interior panels online but didn't care for the design patterns they offered and for $7/8 hundred I figured I could do it cheaper. So, I decided to custom build my own with a marine black vinyl and two 6 1/2 speakers in each Luan plywood panel (got the 4x8 sheet for free).
I'm going to use batting behind the vinyl for a bit of cushion held down with a spray adhesive.
For anyone who has built their own panels did you glue or staples to secure the fabric to the plywood or a combination of both?
Below- Drivers side panel
Got the 2 rear interior side panels dry fit, next step with be to wrap them.
Has anyone used this type of flooring before and have any suggestions on holding down the poly vinyl to the steel wheel well once trimmed up. Epoxy? JD weld product?
I also filled the void behind the panel with high density foam, like the kind you find in heavy packing material. In my mind it helps with noise.... Although you might want some space for your speaker function.
Also while you are back there, replace all/some of your hardtop bolts with eye-bolts. I used closed loop stainless - looks trick and great for tying stuff down if you are out in the rough stuff.
Spray adhesived the batting on, got to clean it up a little and cut out the amp and speaker holes. Had to order a upholstery staple gun as mine won't fit the smaller staples, Amazon $40 with staples.
Screenshot_20260609_183213_Gallery.jpgScreenshot_20260609_183224_Gallery.jpg20260608_214133.jpg
Looks nice. Did you have any backing/foam on the back of the wheel well vinyl? Looks like that would be a bitch to get tight.
Nope, it might have helped but I didn't want anything that could trap and absorb moisture underneath. I tired heating, stretching, rolling it out, the poly vinyl just wouldn't tighten up in some spots and after a couple hours on the first one, I said f#ck it, you're never going to see it when the bench goes in. If it becomes a problem down the road, I think I would just raptor line the wheel wells. I originally thought about it and probably should have and just put the covers on over it, and if I wasn't happy, it would have already been done. Live and learn.
